the s10 is the same as the stock gbody at IIRC 10.5 using hub and rotor on spindle with a single piston caliper.
The 98-03 2wd blazer uses a sealed hub bearing, 11" rotor, and twin piston caliper.
Not much more surface area vs stock but the twin piston caliper should produce more clamping force
