I just got my steel concepts kit yesterday. I'll post my opinion/pics when done, but don't rush me, I'm a very lazy man. It does look pretty sweet though.
Supe said:Do NOT use the stock power brake master cylinder. You need either a factory Malibu manual master, or the manual master from an S10.
Razorblade if you buy this Master Cylinder kit from me you will not had to worry about the rod lenght wich i already have set for you when you receive the kit,as far as the pedal pressure i hit the brakes,and its right there .The master cylinder that you brought off a 84-87 chrysler mini van is not a WILWOOD MASTER CYLINDER.WILWOOD IS AFTERMARET COMPANY,THE MINI VAN MASTER CYLINDER HAS A 3/4'" INCH BORE AND MADE FOR A DISC AND DRUMN SETUP.THE WILWOOD HAS A 1"1/16" BORE AND IS SETUP FOR DISC, DISC SETUP.RazorBlade said:`yes but how many times do you have to pump the pedal to get response??? is the pump firm from the get go or do you gotta pump it?.. i'm running the factory disc in the front and the factory disc set up from QP on the rear.. and the wilwood set-up don't work worth a d###!
80bu said:Razorblade if you buy this Master Cylinder kit from me you will not had to worry about the rod lenght wich i already have set for you when you receive the kit,as far as the pedal pressure i hit the brakes,and its right there .THE WILWOOD HAS A 1"1/16" BORE AND IS SETUP FOR DISC, DISC SETUP.RazorBlade said:`yes but how many times do you have to pump the pedal to get response??? is the pump firm from the get go or do you gotta pump it?.. i'm running the factory disc in the front and the factory disc set up from QP on the rear.. and the wilwood set-up don't work worth a d###!
GreenDragginBu said:80bu said:Razorblade if you buy this Master Cylinder kit from me you will not had to worry about the rod lenght wich i already have set for you when you receive the kit,as far as the pedal pressure i hit the brakes,and its right there .THE WILWOOD HAS A 1"1/16" BORE AND IS SETUP FOR DISC, DISC SETUP.RazorBlade said:`yes but how many times do you have to pump the pedal to get response??? is the pump firm from the get go or do you gotta pump it?.. i'm running the factory disc in the front and the factory disc set up from QP on the rear.. and the wilwood set-up don't work worth a d###!
Ok i have factory front disc and have big ford drums in the back, if it is setup for disc/disc then it probally wouldnt work real well for me then...would it???? Also factory manual master cylinder has a 7/8" bore
GreenDragginBu said:Travis, yeah i deffinetly need all the info on this as possible. like i stated earlier i have tried the factory replacement for power, the factory replacement for manual, and now im using a S10 manual master.
None of them give me enough faith in stopping, that it is a big reason why i havent been to the track yet. and even before you started selling the kits i had heard nothing but good about the Wilwood master cylinders, so i trust ya on that. just after now going on my third try, it makes me a little hesitant on buying another setup, and hoping it works.
thats the main reason im waiting to see when Cherp drives his car, i know he has disc/drum setup.....and i hope it works well with his. then i just need to get the money together. I hope ya understand im not doubting your product...it looks like a awesome piece.
