I have searched and read many posts on this topic but am still a bit confused.
I would like to use the power brake master cylinder with a home fabricated firewall plate and rod using the upper hole in the brake pedal and using the stock proportioning valve.
Will this work with the stock disc front and drum rear setup ?
Also, which line does the line lock go into.
