I have a 2001 LQ4/4l80 out of a 2500 HD truck that I plan on installing in an 87 monte carlo ss. I plan on using LS6 intake, 243 heads, headers, change cam and change the oil pan (for clearance).
I have removed the intake and the heads so far and will be removing the oil pan. Now is it worth tearing into the shortblock or do I leave it as is? The previous owner said the truck had about 30K miles not used on the road. It was a mine (above ground) service truck....so probably lots of idleing.
If I redo the bottom end then maybe I should go with different pistons and reuse the 317 heads....
any opinions welcome.
