Creep in park/tight reverse
Supe
15,116
Charlotte, NC
I moved the shifter and then crawled underneath and checked the detents. They were dead nuts on. I started losing first gear as well. Pulled the trans on Sunday, it's already out of the car. Glide is going in this week.
mattb364
New Member
Apr 26, 2010
Been awhile since I've been into a 400, but sounds like you have a fluid crossfeed into the forward clutch. If I remember, the 400 always had a problem with the case warping by the center support bolt. Check the case with a straight edge.
400 is a very good trans, just be thorough and you should find the problem.
Supe
15,116
Charlotte, NC
It's going to be a while before she gets gone through. The powerglide is already in it's place, but thanks for the info. Never knew the case warping was a problem!
