Piston rings for N20
Ed Cannon
1,682
Johnson City Tn
Trying to get parts together for my bbc build. I plan on using N20 on it, I'm thinking 250 Max. The Probe pistons I'm looking at come with a moly top ring set. Ive been reading and finding all kinds of different ring opinions. Seems like Hell fire rings are a good choice, but do I need rings that good. Or will the moly rings do the job? I want to do this right the first time but I don't want to go broke in the process.
psychomotors
896
Bonne Terre, Mo
JMO but you should be fine. Just file your end gap properly so you don't but the ends under spray. Try http://www.nitrousforum.com These guys eat the stuff,lol.
Excelerater
6,798
Memphis,TN
H ell fire's . . . I got mine Perfect Circle PC479s,but all the companies relable them with some trick name
RdCamaro79
57
East Alton, IL
If your only gonna run 250 shot Personally Hell fires are overkill, If It was me I would spring for It but I do everything overkill!
DeltaT
1,050
Nor Cal
I like to overbuild - use the Hellfires - so when you turn up the wick a bit (come one, you know you will 8) ), you'll be prepared.
In the grand scheme of things, they aren't that much of an investment.
Jim
