Will 86 cutlass electric split bench seats fit in my Malibu
TURNA
6,028
Socialist NY
Re: Will 86 cutlass electric split bench seats fit in my Mal
It will fit , you will just have to wire it up and weld in the inner mounts if it's a 60/40 split and if you don't have them already.
Mymalibuisthepoo
13
I have the mounts that are holding in the factory seat. Will they work or will I need the mounts from a cutlass?thanx
TURNA
6,028
Socialist NY
Is the bench you want to install 1 or 2 pieces?
Is the bench in your Malibu 1 or 2 pieces?
if your bench is 1 piece and the cutlass is 1 piece, then yes direct fit.
if your bench is 1 piece and the cutlass is a 2 piece, Then you will need the inner seat brackets that were in the cutlass.
if your bench is a 2 piece and the cutlass is 1 piece then yes it is a direct fit
Dec 13, 2010
9
this sounds cool, but for some reason i like the 1 single bench mines has, i would love to take it off but worried if i will regret it..
Mymalibuisthepoo
13
I like the bench seats in mine but it doesn't compare to cutlass seat IMO.
