What is your brake system setup? Stock front calipers and stock rear drums?
What size brake master cylinder are you using?
Stock size calipers have a 2.38 piston and are quick take up calipers after the 1981 model years for g-bodies. This size is small for the size of our cars and the quick take up design requires a step bore master cylinder. These calipers should be upgraded to a oversized 2.75" piston. These oversized calipers are not quick up design. Even though the caliper is upsized from 2.38" piston to a 2.75" piston, it still would only need a 7/8" master cylinder or less.
There is a 15/16" master cylinder from a dodge dakota that can easily be adapted to the TRZ manaual brake set up. But I still think it is too large of a master cylinder. There is the step bore master cylinder from the s10 with a 24mm primary bore and a 1 1/4" step bore, but I think this is too large for a stock g-body braking system or with the upgraded larger calipers. This master cylinder would require modification (elongating the mounting holes) to bolt to the TRZ manaul brake plate.
Stock g-body manual brake pedal ratio is 6:1
TRZ manual brake pedal ratio is 5.5:1
Stock g-body power brake pedal ratio is 5:1
The higher the ratio = less pedal effort and more leverage to get fluid to the caliper.
Smaller the master cylinder = less pedal effort and more pressure to the caliper.
