speedway motors tubular control arms
406Monte
1,019
Hubert, NC
What is the reason that some of you are running two upper right side upper arms and not one of each.. I am wanting to do with upper and lowers but am undecided on them. Now, I am rading that some of you are running two rights and now I am confused. I need some clarification on this. I am using my car 90% track and 10% street if that hlps any also. :-k
v8power
511
okc
i have 2 right side ones on my regal. sees lots of street abuse and they are working awsome.
gman415
883
Chattanooga
The Speedway arm are for round track cars, and the drivers side upper arm is longer to change the "pitch" of the wheel.
406Monte
1,019
Hubert, NC
So, then using two right side arms work and offset for the extra length that the left side arms have.
681tonburb
New Member
Jul 11, 2009
4
Correct the 2 right side arms are both more or less same a stock. The left one was made longer then stock to help the car turn left on the track. Looks like Ill be going with the Gbody lowers.
Billy
240
St. Louis, MO
any new info on these? after reading the previous pages there still seems to be some debate as to the pros/cons of this swap
681tonburb
New Member
Jul 11, 2009
4
Dont see how you can go wrong loose a few pounds and in my case no more ruber busing by my turbo down pipe to go bad.
406Monte
1,019
Hubert, NC
I am going to be doing the swap with both upper and lower arms.
681tonburb
New Member
Jul 11, 2009
4
Im going to use the gbodyParts lower A-arms.
