Ok where do you guys run the coolant bypass tube? from the crossover to the throttle body, from the throttle body to ????????????????????
If ur using the truck waterpump there is flat spot on top that is perfect.Apathy93Z said:If not where do you drill the hole in the water pump?
Sorry, you're right.388bu said:You mean f-body pump? There's a perfect spot on top of the f-body pump. Its basically where the truck spout would be.
