I am trying to disassembly my heat-only box and having some difficulty. It needs to be completely disassembled to thoroughly clean, because it was inhabited by mice and smells bad.
A lever for one of the doors needs to be remove from the door in order to separate 2 halves of the box. The hole in the lever is D shaped, so I am assuming it is pressed on.
I have read that some of you have disassembled your heat-only box. How did you remove this lever from the shaft?
Here are some pictures. There is a drop of WD-40 in the end of the lever.
