I used the rod from my power booster. After a destructive disassembly!
Very carefully cut it until it fits using stop as described below.
Also moved the pin in the brake pedal to the upper hole. Grind head flush and press out and weld into position in the upper hole. Then it lines up properly with the master cylinder using the upper two holes in the firewall.
I put an adjustable stop for the brake pedal. There are two holes in the brake pedal bracket, the lower one for the brake light switch and another hole just above. Using a short bolt and a couple of nuts you can make a neat little stop. Choose your rod length carefully taking into account that you need to be able to screw the brake light switch in so a few threads catch.
I am just in the process of bleeding the brakes and will report on the operation of the brakes in a week or so.
Was trying to get the car running for Saturday, but just discovered that I need longer wheel studs on the front for the centerline mags. May just run the steel wheels for now.
If the above is not clear regarding the brake let me know and I will respond in more detail.
EDIT: JUST A NOTE OF CAUTION---------MAKE SURE YOU UNDERSTAND WHAT YOU ARE DOING WITH THIS PROCEDURE. IT IS IMPORTANT THAT THERE IS A STOP SO THE BRAKE PEDAL CANNOT COME BACK TOO FAR AND ALLOW THE ROD TO DROP DOWN AWAY FROM THE MASTER CYLINDER. IF THIS HAPPENS YOU WILL NOT HAVE ANY BRAKES EXCEPT THE PARKING BRAKE WHICH WORKS FROM A SEPARATE CABLE.
WHEN THE ROD LENGTH AND STOP ARE CORRECT THERE IS ALMOST NO PLAY BEFORE THE ROD ENGAGES THE M/C.
