care to estimate?
junk racing
So im building a lil ol street car 79 malibu, built 8.5 4.56 gears cage glide etc. Im kinda wondering what too expect out of this thing, care too make a guesstimate? Here is my combo....
406 half filled studded top and bottom
4340 scat crank
4340 eagle rods with L19 bolts
SRP pop ups 12.5.1
Titan copper headgaskets
Comp custom grind solid roller 4/7 swap
274/288 @.50 .654 .664 on a 113 lobe
RHS 230's cleaned up 2.08 1.60 valves
Team G intake cleaned up and port matched
Pro system 850 E85 carb
speed tech difuser plate pilled for a 200
Built glide 4500 stall T-brake etc
who wants to take a stab at what she runs? and what type power im looking at?
Thanks guys
lilbowtie
1,736
Canton Mi.
That sound about right. If my quess is right you should have 6.80's 1/8 and a 125 shot should net 6.30's. How hard do you plan on spinning the motor?? what size are your tires?? how heavy??
j&amotorsports
120
laurel springs nj
Im estamating a low 10 depending on weight. and driver and tuning. i have 383 10.8 comp AFR 195 heads .570 lift soild roller cam 750 W/ 400 trans brake no power adder 10.70s 1.47 60' all day. 3500 stall converter, with all seats carpet. though 3" exhaust. and slicks. Is not how big things are, its how well it works together.
