I've smoked 3 alternators in 2 weeks. The odds of all three going bad are slim. Help me find what I've done wrong:
I did the serpentine swap with reverse flow waterpump. The alternator and serpentine setup came off of a 91 silverado 5.7L.
I have the hot lead (10 ga.) red wire on the back of the charging post running down to my starter solenoid. The batter hot cable is hooked to the same solenoid terminal. I have a plug on the side of the alternator with a 14 ga wire that is brown. I've hooked this brown wire up to an ignition source that is hot when the key is 'on'.
After about 40 miles the volt meter is at 8 volts, the battery is dead, and I'm limping home.
I've also added a mini-starter and electric fans with this swap. The fans are run off a relay that is only active when the key is on and grounded by a 170* temp switch. The starter is new, but heat soaks and won't start the car when hot.
Where would you guys look first ? I'm driving to work tomorrow, to test alternator #4, and i fully suspect it will be smoked by the time i get home.
HELP.
HELP.
