Alignment ?'s
442force
27
Middletown Nj
i know about the search button and i was looking for sombody to help me out with a few things
i was rebuilding the front end on the cutlass and i did all new ball joints and upper and lower bushings etc...
when i thought about the castor, camber shims....
is there anyone outthere who has any pictures of a correctly aligned drag set up close to stock or? somthing i can base off of? like not set camber to 3.4 degrees and castor to 20*
more like put 3 shims of said thickness in front and 6 shims of said thickness in the rear?
Id like to be a little smarter wording this but im at a lose. the cars in the shop torn down and im about to put the motor in and just looking to save a little time.
Thanks guys
Erik
malibu795
1,496
4
spgfd ohio
i will post up the info i got.... used to be a thread on this... its not in the acrhives :(
Alignment settings for G-bodies
• GM settings...
o Caster: +2.8 deg, +/- 1 deg.
o Camber: +.5 deg, +/- .8 deg.
o Toe-in: .1 deg, +/- .2 deg.
• Performance settings (from Global West Suspension)...
o Caster: +2.5 deg. driver's side, +3 deg. Passenger side
o Camber: -.25 deg.
o Toe-in: 1/16"
increase caster will give you more high speed stability
increase camber will allow you to turn in harder.
442force
27
Middletown Nj
yea i have a good amount of castor. just not sure if more camber or less is affected.
looks like ill be at the track asking to pop some hoods lol for other then looking at there mills
