8:1 compression sbc 355 with an 250 shot of nos
Twister79
163
Orangeburg, SC
well guys i bought an 8:1 compression 4 bolt main 355
the block is o-ring for nitrous, gm steel crank, recondition rods, lunati solid roller cam .656/.668 .316/.330 4500-8500rpm, gear drive timeing set, and mild poted gm 492 angle plug heads with 2.05/ 1.600 valves, 1.5 roller rockers, bowtie victor jr intake, nos cheater system with a 250 shot, holley 750 hp carb, and a tci 3500-3800 converter
2 passes on the motor never sprayed (the guy said he turns this thing 6700 rpm :roll:
i bought everything for 1,200 bucks how do you think its going to run in my 79 malibu with 4.56 gears and p275/60/15 m/t et street tire
Twister79
163
Orangeburg, SC
helloooo anyboady home
That's quite a bit of cam for 8:1 :shock:
Twister79
163
Orangeburg, SC
what time you think it runs on motor ? the guy i bought it from told me 1/8 track motor-8.87 nos-7.12 in an 85 buick regal with 4.56 gears and slicks
cutlass389
684
NC
Stock rods and heads? 8:1? Hairy stick? Not gonna' run for sh!$ by itself. May not run for long on a big shot with stock rods. Might consider stepping the pills down to 125-175.
lilbowtie
1,736
Canton Mi.
I would hope you would run better than that - My 350 has gone 7.18 on motor. You have too big of cam, not enough converter, and heads that are great for mid range
Twister79
163
Orangeburg, SC
what is your setup :D
lilbowtie
1,736
Canton Mi.
I am running a stock L-82 short block w/chevy 64cc 2.02 heads, comps 306s flat tappet cam, Vic Jr
w/750, T-400 w/4000 stall, 4:30 rear w/28 in hoosiers.
