Well guys the stock 305 in my 78 is knocking something bad...so I have been trying to come up with a cheap but reliable solution since this is my current DD. I found a 89 350 tbi with 10k on fresh rebuild for 200, then comes the problem of re-using the stock exhaust. I have found that I can plug the block dipstick provision and reuse my 305 pan with the dipstick in the pan so I can retain the stock exhaust manifolds. my question is this is the 89 tbi 350 a roller motor and if so what would be the biggest cam I can put in it with out needing head work and a stall. Also tbi heads accept regular sbc intakes correct? thanks for the help guys.
