Fuel system help on my lq9
Gthom
19
I have a 87 monte ss I am swapping a lq9 with heads and can, I am wondering what is the beat fuel kit to run.. I have a grand national tank with a racetronics 255 fuel pump and sending unit. So now I need a simple kit or maybe part numbers u guys use to supply the motor and use this pump with a return line.
360demonRT
381
central Ky
the motor, is it a return or returnless style fuel system? if it is returnless, the corvette filter regulator works excelent. just ebay/google it, it's a popular option. other than that i dont know lol, good luck!
J@meson
58
Elizabeth City, NC
I ran -6 PTFE hose with AN fittings for a feed line and used the stock 5/16 charcoal canister vent line as my return line and fabbed up extra PTFE hose I had left over.
andrewmrchevy
32
Seoul, Korea
Vette GF822 fuel regulator/ Filter is best, then you can use the factory line to the front of the car. Best to have the return short and returning to the tank right away. I used 6an fittings as well, same tank and fuel pump as you.
