Board index » TECHNICAL » LSx Tech
Post new topic Reply to topic  [ 1 post ]
 Post subject: Vega LS Swap Headers
 Post Posted: Thu May 10, 2018 2:46 pm
Hi Folks, this is a unusual request, but you've helped me in the past. I'm working on a
71 Vega HB that's a back half car. I'm in the process of swapping a LS 6.0 in and looking
for header options. I've been doing my homework on this and after looking around, it
looks like there's a decent chance that a mid length ( 1 7/8 tube, 3" collector) header
will fit. I've done a rack n pinion swap which allows me to move the steering shaft around
quite a bit. The r & p conversion also replaces the factory K member with the one needed
for the rack. The engine uses a front motor plate so that also frees up some room. I really
don't want to buy a set just to find out they won't work, so I'm wondering if there's anyone
in the Philadelphia area that might have a set I could trial fit ?? If they fit and they're for
sale, I'll be glad to purchase them. If not, at least I know what to buy. If it's just a matter
of tweaking or reworking a tube or two, I have no problem with that.
Thanks in advance for any help
If you're gunna be a bear................be a Grizzly !!
cron
