Board index » TECHNICAL » LSx Tech
Post new topic Reply to topic  [ 4 posts ]
 Post Posted: Mon Dec 21, 2015 2:46 pm
Just found out my new BBC with only 25 min of run time has cut 7 lobes off the cam, frustrated and thinking about going to an LS engine. Trying to weigh the cost of fixing my new engine versus swapping to an LS. Friend has a 105k mi iron 6.0L from a 200-2001 2500 truck, engine is complete with coils, fuel rails, cable style throttle body harness and computer. Realistically i need to know what it will take to get the 6.0L into the car. From basic research I've found out about the 1" set back adapter plates, but need to know of there is any adapters required to mate with my current th400 and converter, and also if I can retain my current 1/2" hard aluminum fuel line and just change pumps etc...Also best and least cost headers that fit well and will flow well. Thanks.
'79 Malibu
6.0LS/TH400
G/N 8.5 w/4.10 's
 Post Posted: Tue Jan 05, 2016 7:27 am
You can get adapter plates off eBay for like $35. You can get the 6.0 to mount to it without a spacer if there's already one on there connected to the crank. Depends what year 6.0. If you don't the extra cost is about $80 from Jegs. There's a lot of little things here and there that would be needed, but before I decided to switch back to old school I was looking at maybe around $2500, including engine.
 Post Posted: Tue Jan 05, 2016 9:48 am
bell housing on turbo 400 is the same as a ls.
 Post Posted: Sun Jan 10, 2016 9:00 pm
https://sites.google.com/site/sloppywik ... ardturbols
Depends on what you want. I have close to 5k in mine still with a sbe. I got carried away with fuel system, injectors, cam, ecu. Ive seen a swap done for 2k though.
