Board index » TECHNICAL » Electrical/Wiring Technical
Post new topic Reply to topic  [ 3 posts ]
 Post Posted: Tue Feb 23, 2016 2:24 pm
Does anyone use a racepak or equivelant dash set up for gauges and replay or logging of data? I am wondering if I can get a dash display that would do wide band A/F, trans temp, drive shaft rpm, and maybe other standard readings like voltage, oil pressure, water temp, rpm, speedo, shift light ect that I could also record the info or at least replay the info to log and help dial in consitancy. Just brain storming here and wondering if anyone has info or personal experience. I don't need drive shaft rpm or even A/F or voltage on display at all times as long as I can log them.
 Post Posted: Sun Mar 06, 2016 10:29 pm
I'm looking into the Racepak IQ3. Part number 250-DS-IQ3LD. The one I'm looking at is the IQ Street.
http://www.motorsportsinnovations.com/R ... isplay.htm
It looks like it comes with odometer, water temp & oil pressure. Things like fuel level, high beams & turn signal all come from the factory harness. The gps kit is also available to take care of the speedo. I believe you can add on a/f ratio & driveshaft rpm but they require sensor kits sold seperately.
 Post Posted: Sun Mar 06, 2016 10:51 pm
I use the Autometer data logger dash in my car.
cron
