The TH350 can be built to handle 600HP/TQ fairly cheap, above there it gets more expensive and a TH400 could be used & built cheaper.
Most of the Pro Builders shy away from the TH700R4/4L60 above 500-550 HP/TQ, a few claim theirs can handle 700 HP/TQ. The TH2004R can handle 800 HP/TQ reliably if properly built with some 4340 Billet parts, above that power level a 4L80E should be used.
For the 700R4 or 2004R Trans to be reliable & last at high power levels they should be built by someone who specializes in them. There're a lot of little tricks that make a big difference.
87-93 700R4/4L60's have the most Factory/OEM upgrades, many newer parts from the 4L65E/70E can also be used in the 4L60, 5-Pinion Planetaries, Drums, Output Shaft etc... Same with the 2004R Trans, 87-90, the newer the better.
Most any Shop can build a stout & reliable TH350 or TH400.
