I'm no expert but from my extensive reading about vortecs they are done making MORE power at 5600. You can spin 'em higher but won't realize any additional hp. Same story with hydraulic lifters. Above 6000 they will pump up and hyd rollers are HEAVY. Even modified, the max USEABLE lift is around .500. Vortecs claim to fame is the good low lift flow and amazing velocity to produce killer torque. 170cc runners are not gonna' support enough air to supply 6000+ situations. My view is to match them with a dual plane intake and a midrange(2000-6000) hydraulic roller cam for incredible torque in the real world rpm range. I'm in the high 11's with a dual plane, stock vortecs with beehive springs(915's), a .492 lift cam with the wrong LSA and not enough duration, shifting at 5200. Shifting at 5500 didn't produce any better times. If you want to make 'er shriek, get some big port heads, a solid cam with the best springs you can get, a single plane intake, and a whole lotta' convertor 'cause there won't be nothin' below 4000 rpms.
