Trunk popper???
MALObu
233
los angeles,ca
Looking to install a power trunk popper(factory) on my SS and need ALL & ANY knowhow/insight of HOW to go about wiring/connecting it? Also,the one I picked is from a 4door sedan Mali,will this work?I've done a swap before on another SS and I could of swore there was one side that had a connector on it that went directly to the fuse box??!!?? As for the one I picked from the sedan has a pigtail comming out of the button side that that is grouped together with the climate control speed control? Hope I'm making SOME sense,if not I can get some pics up of what I'm working with in a few days ?
80malibucoup
634
Jonesboro,Ga
one wire goes from the fuse box to the botton,then from the botton to the "popper" it self. the "popper" is the ground for the whole thing so no ground wire needed.
