They are just hard inverted flare lines, you can buy at any auto parts store and bend yourself... actually pretty cheap... They may vary in sizes, so you may take one off and bring it with you. When I worked at "The Zone", we had rolls of rubber transmission cooler hose in the back you can uy in bulk, and hard lines with the fittings already on each end...
Have you tried a hydraulic hose shop? If you have an industrial area around you, you likely have a hydraulic hose shop that makes pretty much any kind of hose you could want.
