Having a major leak out by the tc, pulled the trans out to do a pump seal replacement, and after removing the seal noticed a large groove going across the entire width of the pump body bushing, that suppose was done by the last guy that changed the seal or a prior rebuild.
The question is: how hard to pull the pump from the case, in order to disassembly the pump to r&r the bushing?
Looking at the various manuals around the house, it says to use two slide hammers, which I don't have.
Once the pump is removed from the case, what other seals and such should be replaced besides the large square cut pump body to case "o" ring and front pump to case gasket?
Thanks for any responses.
