TCC AND VEHICLE SPEED SENSOR(VSS)
45CHI
40
WITH MY 5.3L/LM7 STAND ALONE APPLICATION WITH TH400 TRANSMISSION 1}DO I NEED TO CHANGE THE BRAKE SWITCH OR DOES IT STAY THE SAME? AND 2}WHAT DO I DO WITH THESE VSS WIRES? ](*,) ](*,)
bigmandengo
60
madison, wi
With the th400 you dont have a lock up converter, so the ecm doesnt even need a brake switch signal. Do you have the Vss hooked up to the th400? Ideally you should get a vss signal from the transmission for everything to run properly. Dakota Digital sells a sensor that hooks to your mechanical speedo output and is compatible with the ecm.
part# SEN-01-4160
45CHI
40
THANKS 8) THATS WHAT I GOT FROM MY RESEARCH. ALL I HAVE LEFT TO DO IS THE WIRING FOR RELAYS, FUSES, ....BASICALLY EVERYTHING TO START ENGINE
