Stuck squirter
unclepudge
348
CT
I noticed the other day I was out of windshiled fluid so I refilled it and when I turned the wipers on to get the fluid through the lines it just started pumping out by itself and wouldn't stop til I shut the switch off,as soon as I turned the switch on again it started to pump the washerfluid out again?
Longroof79
8,948
9
Gainesville, Fla.
Your washer pump sounds like it might be FUBAR...the stock cam actuated washer pumps suck. I eventually plan on changing to a universal type washer pump...kinda like a fish tank pump. You'll find them in any good auto parts store.
Jack
unclepudge
348
CT
Thats what I figured as I tried tinkering withit to no avail. I here the washer actuate when pushing the button but it just won't stop squirting I tried to clean it up but still the same,I plan on converting to delay wiper with column switch so I will have to replace it anyway?thanks again for the help.
Longroof79
8,948
9
Gainesville, Fla.
No problem. Mine actually did the same thing as yours is doing. It hasn't worked in years, because I never bothered to replace it.
Jack ;)
maliburacinfreak
2,842
evansville, in
mine did the same on my 2dr....i just unhooked the hose. :lol:
