Got it installed with an Energy Suspension trans mount which was a tight fit...........it raised the trans a little which now leaks at the tailshaft housing at the rate I drop every 2 minutes......my 9C1 700r4 has the trans mount attached at the tailshaft so there is now deflection on the trans/ or at the tailshaft.............has anyone else had this problem installing a non-factory crossmember? If so what was the solution....thanks..........
