Rear Spring Question
ALaRock
128
jackson, mi
My question is anyone running QA1 14-150 Coil Springs in the rear in place of the stock springs? Also, can i use the Air Lift drag bags with these springs? I am trying to accomplish a slight rake from the rear to the front. Thanks.
ALaRock
128
jackson, mi
Anyone?
buwagon78
109
New albany, Indiana
In my 78 wagon I don't use the QA1 springs but I do use the air bags in stock springs and they raise the rear about 2 inches at 20 lbs, but the rear gets really stiff (the air bags are really for spring rate control instead of lift). This is what I want in my drag car on the right side, but would be rough in a street car. They fit tight in the stock springs and I don't think would fit in the QA1 springs.
Somewhere in the site is a chart for what springs to use in each car type. You could probably find one of the QA1 springs with the load rate and height that you need.
Hope this helps some. Rob
ALaRock
128
jackson, mi
Thanks for the information Buwagon78
