Problem with my new brakes...help
Malibu 361
1,286
Queens,NY
My entire system is new ...Wilwood tandem MC, Wilwood 4wheel discs ,proportioning valve...Ok,the problem is when the brakes are applied the rears lock up and the only way to un-stick them is too crack the fitting at the master any ideas??Thanks
Are the hoses new, too? Sometimes old hoses will "stick" shut & the fluid doesn't return to the master, causing the brakes to stick or drag.
