I'm looking at buying a used factory GM roller cam with 155 cpc bc 11 stamped on it. Can anybody help me ID its application and specs? It is for a SBC.
The two possible projects I had in mind for the cam are:ScotSea said:305 AT LB9 10088155* 0.35 0.384 179 194 109 (108/-112)
Often called the peanut TPI cam. 179 intake duration, 194 exhaust 109 LCA.
Scot
ScotSea said:The stock L98 roller cam might not be too bad:
305 5spd / 350 AT 14093643 0.404 0.415 202 207 114.5
I have a TPI Vette, and the gas mileage with this cam is pretty good. I bought a ZZ4 cam, and might try that too. Just a little more intake duration (208), but even more exhaust duration (221). Lots more lift.
If you are looking for a cheap cam, I would bet that you could get the stock L98 cam above pretty cheap. The ZZ4 might cost more, but offers a little more performance. Just what are you goals?
Scot
Scot
ElCaminoBill said:What is you opinion of the LT1 cam? A friend has one, new in the box. He bought it when he was planning a stock rebuild on his Camero but went more radical.
