Ribbedroof said:
A few questions...
Figure a 2" cowl would clear the intake w/o cutting anything?
I assume you used the OE harness and can you tell us did you eliminate anything like rear O2 sensors, etc?
#8 clear the A/C box OK?
Town car xmem...92+ I assume?
Have you gotten a "seat-o-the pants meter" feeling on performance?
I ask because I have found a 2000 5.3 pullout, eng/trans (40K), harness and PCM for $500...friend of a friend deal.
cowl will fit with the mods i have done....just eliminate the vapor purge valve on the top of the intake..
rear o2 can be deleted by hptuner setup and reprogramming....i still haven't finished all the wiring, but it is a 2 wire hookup if you have the fusebox. also have whovever does the tune eliminate the antitheft so it will start.
number 6 is great...if you are limber you can reach #8 from the top(it's a lot easier than a stock buick v6), but you may prefer my mod...
xmember is a 92 if i remember correctly....
i'm going to run the g-tech this weekend, but i've put a length on a 12.8 second car from 30 mph to 110...
and if you don't buy the motor for $500, i'll kick you in the jimmy....hard.
