I have just finished mounting my battery in the trunk with the main kill switch mounted on the rear bumper. The installation went fine so I thought I would try it by turning the switch when the car was running. The car KEPT running when I turned the switch. I thought about it and concluded that I needed to isolated the charge wire from the alternator to the same side as the battery lead on the kill switch. I have done this as well but have not tried the kill test again yet.
I am using the factory amp gauge in the gauge cluster and also using the factory plug on the alternator. It has a red wire that comes out of the plug (about 4" long) and bolts to the back of the alternator with the "charge" wire that I run back to the battery side of the kill switch.Of coarse I dis connected original "charge" wire and tied it off. The other smaller wire on the plug (brown) goes to the gauge.
The alternator I am using was new last year as a 130 amp replacement (instead of a one wire alt)
So after explaining what I have done here my question is(before trying the kill test)
Is using that factory style plug going to cause any problems or will I have to go to a one wire alternator?
Done this before?
Thanks!!!
Done this before?
Thanks!!!
