info on a factory posi
455_82malibu
1,400
WISCONSIN
Ill run it and toss it if it does start to slip, but the cones look like new and I plan putting a small tack weld on the outer shell where its bolted toghter, If my stock s clip posi is holding up this has to be an upgrade.
455_82malibu
1,400
WISCONSIN
I have a GN /442 8.5", im just using the caprice guts...they come with 30 spline posi's
malibooyah
New Member
Dec 2, 2011
3
anybody know where I can get a posi and 3.73 gears for my 1980 Malibu? I was told with my almost stock rebuilt 350 I don't need to upgrade to 8.5,instead beef up my factory rear.
468malibu
425
Binghamton NY
I have a factory posi in my 'bu, but need to find a 9" first. Also has just 3.08s I think...
MalibuMan1979
506
flint, (lapeer), michigan
check the junkyards. i found a 7.5 posi in a elcomino. bought a richmond 3.73 gear set. hasn't broken yet.
LSJM1
134
Atlanta
I just picked up a 8.5 rear from a 92 caprice same deal 30 spline auburn I was going to use the posi unit in a 71 cutlass 8.5 rear I have and buy new axles
The caprice rear is about 1" wider than the A body rear which is 1.5" wider than a g-body rear
The upper ears are way wider than a or g body you would def need some custom upper arms
I never took an Auburn unit apart do you pull the end plate off it or leave it together and work it like an eaton
