HVAC Door Foam Replacement
4,665
32
I am refurbishing my non-AC heater box and want opinions on what to use on the doors that used to contain rotten foam. Without some sort of seal, the doors will leak.
Please let me know your thoughts.
Mike
1,709
New York
Re: HVAC Door Foam
How about the foam tape that is used on a pick up bed when they install a cap ?
Re: HVAC Door Foam
If it's what I'm thinking, that's way too thick. The foam he needs is closer to about 3/16" wide and thick... The foam for truck caps is more along the lines of 2-3" wide and probably 1/2" thick.
4,665
32
Yes, it is thin and needs to be compressible. It could cover the entire door, but doesn't have to.
I am hoping there is some sort of product that I can use that doesn't rot and become gooey after 10 years and then blow into the passenger compartment...like the original stuff does.
I cannot be the only one with this imponderable.
melloelky
3,654
31
mass
I've used some of that adhesive foam from home depot,its under foam tape,rubber foam weatherstrip,foam insulation tape,closed cell weather seal tape. comes in different thicknesses, colors etc etc.one of the company's that make a lot is called frost king. I'm sure you could find something there to work for ya.
4,665
32
melloelky
3,654
31
mass
their are a lot different versions of that tape i didn't know what would work for you.its worth @the store
