How to calibrate speedometer
81classic
2,833
North Port, Fl
Ok, I need to calibrate my speedometer to my current setup. I see lots of calculators but have never changed the gears before. It looks as one has to have the tailshaft removed and the other pulls out of the side. Do I have to remove the current gears to have a starting point? I have a TH350 and Autometer Speedo with 27" tire
SSedan64
948
MACON, GA.
You may only need to change the Driven gear on the side.
You can count the teeth on the Drive gear by looking thru the hole when the Speedo Bullet/Housing is removed. "This needs to be removed before Tailhousing". << if needed.
http://www.bgsoflex.com/speedo1.html
http://www.chevellestuff.com/tech/speedo.htm
http://novaresource.org/speedo.htm
81classic
2,833
North Port, Fl
thanks, I was shocked to find out GM had the speedo gear in stock.
