HELP! new transmission and problems
Preacher
15
Have a THM 400 (Summit) and it has less than 1000 miles on it. It has now started slipping bad in 3rd gear - especially at WOT
1. vacuum modulator good, not leaking and receiving vacuum from back of intake
2. kickdown wired correctly 12v @ WOT
3. trans fluid good, clean and full
4. ??????
Screen is dirty?
SSedan64
948
MACON, GA.
A pressure check will help locate the problem.
0-300psi Pressure Gauge. Test Port is on driver side about mid pan area.
http://www.amazon.com/s/ref=sr_nr_n...=1358032851&rnid=15690151&tag=maliburacing-20
2-3 Accumulator > Piston seal leak, Pin leak at tapered end.
Direct Clutch > Piston seal leak, Check ball leak, excessive clutch Plate clearance.
Center Support > Seal leak, loose retaining Bolts, excessive Support Bushing clearance.
