elec fan wiring
grizwald
3,300
Ontario, Canada
has anyone wired up an electric fan setup from a 99 concorde? a friend of mine bought one but is having a hard time wiring up the 2 fans. did you run each fan seperately on its own switch? any info you could pass along would be appreciated.
thanks!
mr.melon
68
Harvey.IL.60426
if its the same as the 99 intrepid fan then yes it will need 2 switch to get both speed to get it working correctly if you power only 1 both fan will work but on low wire both at the same time and get high speed going heres a link i ound that will explain it all http://www.montecarloss.com/community/ubbthreads.php?ubb=showflat&Number=183709#Post183709
