I want to get rid of the big Ol' fan and shroud in my Meano....
My plan is to replace it with an electic fan. I have found some 10" fans that are in the $50 range and are rated for 1000 cfm and the temp switch runs about $25.
is this enough to move an adequate amount of air for the 3.8 ive got in there now, (Keep in mind that intend to do a 350 swap eventually) or is there one from another vehicle that i can source one from that will be is sufficient to keep temps in check? Is the stock 3.8 radiator sufficient for a 350 too? Or do i need a different Radiator too.
Id like to do this once so ill have the parts in place for the swap and not have to do it again later. Basically any upgrade i do now i want to work with future mods.
which route would be best?
Suggestions?
Suggestions?
