Shawn F. said:Thanks for the info guys. When it comes to heads I am a complete idiot and know very little about them. I am going to buy the 290HP Crate motor heads for now and use them on the El Camino but for my 63 Chevy II wagon I will run the Vortecs or the aluminum ZZ350 heads that they come with which I am guessing are a little better than Vortec?
For the El Camino I am hoping to push 350-360 HP but now with the heads I am running and cam I doubt I will even hit 310... ](*,) Oh well, as long as it's reliable and half way decent on fuel I will be happy. I will be running this 355 with a TH350 transmission (unless I find a VERY good deal on a rebuilt 200-4r) and the 2:56 gears so mileage is probably not going to be so well. The only thing that helps is the 2:56 gearing. The TH350 is killing me but then again around town it should be good for stop and go. :?
Funny you should mention crate motor heads.
That is exactly what my present motor has.
Here's the description from GM's catalog:
CYLINDER HEADS:
12356026 Cast iron head with 1.94” intakes
and 1.50” exhaust valves. Used on our 350
HO, this head is a good performance head
to 6000 RPM and the 64cc combustion
chambers yield a 9 to 1 compression ratio.
My 'Bu's 355 had 250 miles on it when I bought the car and the guy bought the heads brand new from GM so I'm sticking with these heads for the foreseeable future.
No, they don't flow near what Vortec's do but they'll "do". Nothing a little spray won't take care of.
They ARE center bolt valve covers (no leaks) BUT they have the old intake bolt pattern (GOOD!)e.
Any idea what part number the head is you're looking at?
No, I'm 90% sure the ZZ350 heads do not flow as well as the Vortec's.
As for your gearing and transmission worries......DON'T worry.
With 2.56's and the 350 turbo, you have a "built in" overdrive.
Put a 200-4R in front of those gears and you'll be barely idling at highway speeds.
With a 200-4R, you could run 4.11's and STILL not turn the RPM's you do now on the highway with the 350 turbo and 2.56's.
More gear and the slightly deeper first of a 200-4R would be a BLAST in your car.....kinda like what I'd like to do, actually.
I have 3.73's and a 350 turbo right now.
It turns some RPM on the highway but nothing catastrophic by any means.
But mine is not a daily driver, either.
Ain't overdrive awesome?
