I pulled the instructions out of the box, and it lists part number 2049, and it says GM intermediates with 305/350 V8. The seller told me that he had the same set (not the one he sold me, but the same part number) installed on an El Camino with the factory 4 speed and mechanical clutch linkage. The parts that are in this kit look virtually identical to the Edelbrock TES that I have on my Monte Carlo. There are only several minor differences (Hooker set has a 1 piece Y pipe, Edelbrock's is 2 piece, Edelbrock Y pipe has the 4 hole flat flange to connect to the Monte SS catalytic converter, Hooker kit doesn't). Both kits are equipped with A.I.R. tubes on the headers, have a heat stove for the tube which runs to the air cleaner, the left header has a bung welded in it for an O2 sensor, and will fit a factory heat riser valve. Up until I found this kit for sale locally, I didn't know that Hooker made a kit like this. I guess it didn't sell very well, which is probably why it was discontinued.
