StreetBu
4,158
3
Upstate NY
Just ordered tires for it. Don't even have the wheels the fit the tires but they were on clearance for $84 each for 275/35/18 so I couldn't pass it up :)
78elk
1,294
81
Mountain Home Id
I pulled the steering wheel off today. I'm cleaning to to paint with SEM light oak to match the rest of the interior. While it's off I plan to check the ignition switch.
malibuguy
3,775
Finksburg, Md
jammed the toyota motor back in it and my buddy and I pushed it out and turned it around and stuffed it in the other side "cold side" of my garage. That build is on the back burner until I can bring it up to my shop to do all the heavy fab work.
put my tercel on the "work" side...since well I drive it often and that side has the electric garage door opener :lol: i'm tired of having a few extra things to do to leave and arrive. I am back to button status!
StreetBu
4,158
3
Upstate NY
Big brown truck delivered my 4 new tires today :D now I need to save my pennies for the wheels to mount them on LOL
78elk
1,294
81
Mountain Home Id
I had problems with the E Brake handle pulling through the dash. I took a body shim and reformed it. I bent the top over and shortened the legs on it. With the handle in the dash, I slipped the shim over the back of plastic , placing it next to the back side of the dash. Now the handle won't pull out.
78elk
1,294
81
Mountain Home Id
When I put a dash cap on my dash, I had problems with getting the screws in the holder on the firewall. So while everything is loose, I drilled holes from under the dash. This got the screws in the right place and the dash is very secure. I now need to fill 2 holes in the defroster vent.
