malicad
1,383
South Milwaukee, WI
Spent the day carving pumpkins and lounging with the kids...it's been raining since 6 AM, and the garage where my wagon is doesn't have electricity, so I have to push it out to work on it. I hope tomorrow is better...
200KSS
534
Southeast Missouri
Tried to take the Monte to the Menard's Chevy Show at Gateway yesterday, but the car was mad at me for neglecting it most of the summer. Started backfiring on the highway so I turned around and grabbed another vehicle.
Should probably fix that today.
reel01
901
Philly
Installed a pain in the A** "strange" master cylinder. And push rod. What a pain. Still not done. Can someone help me with this front brake line. Where it connects to master cylinder. The male flared fitting is bigger the female whole on the master cylinder. HELP ME. PLEASE
TURNA
6,028
Socialist NY
Nope not that bad I have seen worse.
Rockers and number 3 mounts are ok but the pass side torque box needs a little help so I have to pull her off the frame
78elk
1,294
81
Mountain Home Id
I put the jackstands in again. Removed the bolts from the fan shroud and flex plate cover. Drained the oil. Jacked up the engine pulled the bolts out of the motor mounts. Jacked it up more then put the bolts back in.
prairiehotrodder
1,576
Melfort Saskatchewan Canada
fired up my motor today after installing a new cam and a tunnel ram with two new 750 holley track warrior carbs.
