Post new topic Reply to topic  [ 14 posts ]
 Post Posted: Wed Mar 30, 2016 11:46 am
Read a few reviews and I wasn't quite sure the centerlink swap would work. Had read guys saying they had to cut the skid horn off the crossmember etc... Well I did the swap and it works out fine. Skid horn does not need removed. I had to trim down my tie rods by about 1/2" per inner and outer ends. Went ahead and swapped back to the longer gbody pitman arm while I was under there. Also hit up Gboz on here and finally got a Jeep steering shaft. Whole reason for the upgrade is a new alignment was in the works after rebuilding the control arms and the old center link ran a little downhill - always lightly rubbed on the oil pan on the passenger side. Now I have plenty of clearance everywhere. I will upload the pictures to my photobucket so I can share them.
Stock Centerlink
DS 1049 centerlink installed
Gboz jeep shaft
1979 Malibu Grocery Getter 1/8th mile best 6.92@97.2 mph @ 3400 lbs. 1.4529 60ft More to come, maybe a 6.8...
406 SBC-4 bolt main/5500/TH-350/4.56 12 bolt
Scat 9000 crank/Eagle 5.7 H-beam Rods/SpeedPro forged pistons/AFR 195 Eliminators
 Post Posted: Wed Mar 30, 2016 12:37 pm
What is better about this setup?
1980 Malibu coupe 468/th350
 Post Posted: Wed Mar 30, 2016 12:43 pm
This is what AFCO has to say...
Improved geometry drag link relocates the inner tie rod end to shorten both tie rod assemblies, which improves steering geometry by reducing the excessive toe out that is common to GM Metric chassis during normal suspension travel (bump steer).
For me personally, it lowers the inner tie rod connection point which gave me more oil pan clearance that I needed. It also allowed me to keep the jounce bars going from the skid horn to the frame rail ends. If you are swapping a worn center link this one is worth considering. *Does require tie rod ends to be shortened*
Also don't pay the $90 for the AFCO link, I got a TRW on RockAuto for $25 shipped to my door
 Post Posted: Sat Apr 09, 2016 4:29 pm
Interesting. 3rd gen F-Body? That'd make 3 Camaro parts on my Malibu :lol:
MR.com Facebook page
'87 Fiero GT - 2.8/5-speed
 Post Posted: Sat Apr 09, 2016 4:31 pm
Ysssir, rock auto is the cheapest place I have found - Trw or moog
 Post Posted: Sat Apr 09, 2016 4:58 pm
Lower rear control arms fit as well 3rd and 4th Gen
 Post Posted: Sat Apr 09, 2016 5:10 pm
I need to do this when I change out the rest of my suspension
-Greg...the Exhaust Guy.
--'84 Bonneville 311/200r4/4.11 8.5...soon to be drag sleeper
Past Malibus,
-79 Malibu 4dr
-79 Malibu 2dr
-80 Malibu 4dr
-79 Malibu 4dr
-83 Malibu 4dr
 Post Posted: Sun Apr 10, 2016 2:47 am
Do you have a link to the centerlink you bought from Rockauto?
 Post Posted: Sun Apr 10, 2016 9:42 am
Part number search DS 1049. Thought about buying all the TRW ones they had left and selling them for 35 shipped. Might have made $5 a piece. Figured it would be better to put the information out there for you guys to get them on your own. I got the car aligned the other day and the guy was able to get 7 degrees of + caster with the stock arms
http://www.rockauto.com/en/moreinfo.php ... 332&jpid=0
 Post Posted: Wed Apr 13, 2016 3:21 pm
So does this new center link improve the suspension geometry like the afco centerlink?
 Post Posted: Wed Apr 13, 2016 5:19 pm
It's the same part as the AFCO centerlink!
 Post Posted: Tue Apr 26, 2016 5:13 pm
I am learning myself but don't they make Mr Ackerman unhappy?
 Post Posted: Sat May 27, 2017 10:45 pm
Also don't pay the $90 for the AFCO link, I got a TRW on RockAuto for $25 shipped to my door[/quote
"Does require tierod ends to be shortened", how exactly do you shorten them, are we talking more turns into the tr sleeve, or actually trimming down the tierods themselves ?
 Post Posted: Mon May 29, 2017 10:21 am
Part number?
How much did you have to cut of the tie rods?
1980 Malibu BBC T-56 9"
1986 Oldsmobile Cutlass.
cron
