Post new topic Reply to topic  [ 205 posts ]  Go to page Previous  1 ... 10, 11, 12, 13, 14  Next
 Post Posted: Thu May 01, 2014 6:24 pm
Im running a 15x4 1.75 back space in the front, and a 15x8 4.5 back space in the rear. Front tires are M/T Sportsman S/R 26 tall. And rears are Hoosier Pro Radial 275-60-15. The rears rub hard on the lip and the frame. I do have the car setting pretty low though, and the tires are tucked quite a ways.
I plan to frame notch and mini tub.
 Post Posted: Fri May 02, 2014 7:32 am
malibulvr wrote:
When using std drum brakes, the 4.5" bs 8" wide wheel usually is ok with up to a 255/60 street tire, but a 275/60 will usually rub the frame. If you are using a stock length rear with iron brake drums then an 8" wide wheel 4" bs should be great. Keep in mind if using the factory aluminum brake drums or a disc brake set that they are a bit thicker than the factory iron brake drum.
As mentioned by malibulvr....... I just went from a 8" wide 4" BS steel GM rallys wrapped with MT ET Street 275/60/15 Drag Radial that fit perfectly in the well, to Weld Draglites 8" wide 4.5" BS wrapped with MT ET Street Drag Radial 275/60/15 and it was a 1/8th of an inch from the frame rail, so I machined a set of 1/4" aluminum spacer and they tuck in nicely! Stock width aluminum drummed rear, Monte SS springs, KYB gas shocks, No frame notch, and no lip trimmin' needed..................
7.70's in the 1/8th, 12.20's in the 1/4!
Full interior, Street driven Chrome bumpered
Iron Headed 355 SBC
80 Malibu355 TH350 3800 stall 4.11's Street-Drag
71 Chevelle 396 SOLD
84 Cutlass, #1 Sons ride, finally 327 powered!
2010 Black on Black HHR,,Family Wagooon!
99 Hoe 4x4
99 Z71 Extend-O Cab #2 sons ride
99 Hoe 2WD Texas truck #1 sons ride
http://photobucket.com/HPJUNKEY
 Post Posted: Fri May 02, 2014 8:39 am
Newbie
How low do the monte ss spring lower the car. Im looking for 2-3 inches in the back
 Post Posted: Fri May 02, 2014 10:07 am
Show us a picture of the "tuck"
Here is how mine is setting right now and it hits on BOTH the frame and the wheel lip (even after trimming) Hoosier 275 Pro Radial.
 Post Posted: Fri May 02, 2014 11:02 am
I dont have any pics with the Draglites on, just put them on Wed. night :lol:,,,but,,,, here is a couple of older shots with the GM 8"Wide by 4" BS steelies same tires as on the Welds,,,,,Still have the Monte SS springs,,,8 yrs running those springs,,,,,,,,,,,,Like anything with age, they are probably "sagging" a bit :lol: :lol: Last year I changed to 3" X-pipe exhaust and have since tucked the exhaust up more and plan on dropping the rear 1" more this season................
Iron Headed 355 SBC
99 Hoe 4x4
 Post Posted: Fri May 02, 2014 11:22 am
The Monte SS springs are part of the F41 Suspension package from the factory, I don't think they would lower it 2-3 inches from "stock" but I'm not sure.................
Iron Headed 355 SBC
99 Hoe 4x4
 Post Posted: Fri May 02, 2014 1:18 pm
ah yeah, a bit higher then I have mine setting. I was wondering how you could get it to clear, but I see now. My section width is nearly 11.5 inches and Im trying to tuck it up to the "fattest" part of the tire. Car looks good though man!!
 Post Posted: Sun May 11, 2014 5:46 pm
Sorry for the late reply.
The pic here is from the center of the wheel looking up. The yellow line represents where the fender lip is after rolling it and spraying it with black undercoating to stop the paint from chipping.
 Post Posted: Wed Jan 07, 2015 12:44 pm
Newb Malibu owner, going for the hubcap on rally look. Rear end is a 12-bolt.
From What I've seen on this forum everybody says they're running a 4.0 BS for the rear wheel.
Will this work?
Front: 15x4 2.5 BS
Rear 15x8 4.25 BS (going on a 275 MT)
These are the only options I see on Jegs, Summit etc...
http://www.jegs.com/p/JEGS-Performance- ... 9/10002/-1
 Post Posted: Sun Feb 22, 2015 5:40 pm
Will this work?
Front: 15x4 2.5 BS
Your backspacing will differ based on what 12 bolt you put in the car and or if you did any modifications the stock axle length.
I have a 67 chevelle 12 bolt and I am running factory 15 X 7 rally wheels. The wheels and rear end are stock from 1967. Just an FYI.
1980 Malibu Classic
A/C delete
402 BBC
M-21 4 speed
 Post Posted: Fri Jun 12, 2015 6:29 pm
1999 (?) C5 Corvette "wagon" wheels (what else to put on a Malibu wagon :lol: )
Front - 17 x 8.5 with 245/45/17 Michelin Pilot Super Sport tires and a 2" spacer.
Rear - 18 x 9.5 with 285/35/18 Michelin Pilot Super Sport tires and a 3" spacer.
Life's a Drag?...Race!
 Post Posted: Mon Aug 10, 2015 9:48 am
looks great
 Post Posted: Thu Sep 03, 2015 6:43 pm
I have not installed them as of yet however, I will be using 06 C6 wheels on the Malibu
all 4 front wheels but modding the rear a bit;)
18x8 front w/245-40-18
Rears are being widened to 18x10 w/285-40-18
Bell tech 2" spindles
Strano custom 2" rear springs
'80 Malibu, 12-bolt, 4.10s, 5.3, 799 heads, baby cam, TRZ arms, C6 wheels, Ls1 brakes, 2" Belltech..more to come..
'93 TA, 5.7 Ls1 forged , T56, 8.8 w/3.73s, LG cam, 243 heads,NX
 Post Posted: Thu Sep 03, 2015 8:20 pm
I'm replacing my C5 "wagon" wheels with the same exact style this weekend. But I'm replacing them with the same size that are on there now, 17x8.5 front and 18x9.5 rear.
 Post Posted: Tue Dec 08, 2015 10:29 am
updated pic with the new wheels.
Users browsing this forum: No registered users and 0 guests
