speedkills80
270
Omaha NE
www.topdogpowdercoating.com
235 R 60 15 front
245 R 60 15 rear
12 bolt with UMI upper and lower control arms as well as upper and lower stiffiner.
The 12 bolt is out of a 67 chevelle. 15 X 7 rallys with factory 4 1/2" offset.
http://www.youtube.com/watch?v=mvrC7vIifmg
WhiteMalibu79
29
Mooresville, IN
purecrazy said:
yeah, I wanna see more of MalibuJoel's black 'Bu! that is one sharp car!
I'm running 15x8 ralley's, with 205/60 BF Goodrich's up front, and 275/60 BF's in the rear...4 inch backspacing in the rear, I'm assuming the same up front...everything is stock, e.g. brakes, frame, etc....good clearance all around
Found these....
http://www.cardomain.com/ride/838428/1980-chevrolet-malibu
malibulvr
1,929
Pensacola, Fl. 32526
Haven't posted my wheel tire combo in a while, and never in this thread so here goes...
Front wheels are 15 X 4 and have 1.75" backspacing. Have 205/75/15 (27" tall) tires mounted on them.
Rear wheels are 15 X 10 and have 7.5" backspacing. Rear tire is M/T ET Street 28 X 12.50-15.
Have a '68-'72 Chevelle 12-bolt rear, 12" 150 lb coil over springs, and full/max frame notch with 36" mini tubs.
On the way to the shop for cage, tubs, and chassis work.
By malibulvr at 2011-07-08
Just came back from the shop I think my cage is hidden pretty well from the side view. Please excuse the driveway mattresses as I also was convinced by the wife to replace our mattresses the same day I brought my car home.
tripdagoat
18
Wallingford Ct
Weld Pro Star 15x8 3.5" BS with 275-60-15 Nitto Drag Radials on rear, 1/2" clearance between tire and frame rail, outer lip rolled so sidewall didnt get cut
Weld Pro Star 15x4 up front with skinnies
Upgrading to C6 Brakes so 18's here I come
81classic
2,833
North Port, Fl
Billet Specialties Street Lites
15x4 with 165/80/15 on the front
15x8 with 255/60/15 ET Street Radials on the back - 5.5" backspace with 1971 Chevelle 12bolt rear
Stangboy
833
Ky
my406cid said:
20x9 front and rear standard offset 255/35/20
Where are the pics and why I can I pm some of these people?
