You're on the right track Looking at the site before I wasn't able to find the brackets alone, but I found them this time around. I'd get the rest of my parts (hoses, calipers, pads, rotors) from Autzone, etc., anything that had a lifetime warranty. If you want a parking brake (like I will with having a manual trans) you can use a set from '79-'85 Sevilles.monte80 said:I found a kit from speedwaymotors.com for under $300 but I think it will be better to buy just the caliper brackets part#91641010 for $10.99 From them and buy all the other parts from a local autoparts for the warranty but the salesman doesn't have/know what's the parts and other info on the swap now what I would like to know if anyone used this kit or if anyone knows what parts I will need to complete this swap
https://www.speedwaymotors.com/images/pdf/910-31923.pdf
They also carry the correct disc-disc valve for changing everything over:
http://www.speedwaymotors.com/Disc-Disc-GM-Proportioning-Valve,13539.html
