New Product- A-body 12-Bolt to G-Body Swap Upper Control Arm
slimbo
4,223
www.yellowbullet.com
run a spohn sway bar. you cant beat it. my junk goes consistent low 1.40 60 foots with it and umi double adj uppers and tubular lowers. stock springs and no air bags.
Jackal
228
Orillia, Ontario, Canada
Eta on non-adj uppers?
h2opunk182
96
Seaford, NY
whats the easiest way to install the bushings for the adj uppers.. i've tried grease, freezing them, and a bushing install tool, the only thing i haven't tried is a press.. which i don't have.. do you have any other recommendations??
Lovemy1981Malibu
535
Kettering, Ohio
I had mine professionally pressed in by a local machine shop. It cost me about $50 to have the old bushings removed and new urethane bushings pressed in.
406Monte
1,019
Hubert, NC
Ryan sent you a pm
dooorslammer
New Member
Feb 4, 2010
hi
I race 1980 malibu in nhra stock class k/sa . the engins is a 305 with stock specs
this car does 60ft in 1.52 average with a best of of 1.48 . What i would like to know is what really made the biggest improvement . please only front and back suspension
nothing with engine ,convertor, trans or gear ratrio
any help would be greatly appreciated
peter b 5749
Japc74
22
Re: New Product- A-body 12-Bolt to G-Body Swap Upper Control
I am in the process of doing thus conversion. I want to know what is the biggest tire and tim combo. Including rim bs. I think I saw somewhere that the a body 10 bolt is a little bit wider than the g body 10 bolt. Some help please!! Thank you.
