Manual brake conversion kits
so if i want to convert my 81 bu to manual brake...
all i need is a new back plate & a manual master cylinder?
no valve changes or anything...
cause i know with manual brakes ya got a better braking car... (I drive in stop & go traffic everyday)
want to make sure this is a good idea for my car, a 4 door i carry my family in
10 inch tires
67
Fairfield/Vacaville Ca.
steel concepts said:
Supe said:
10 inch tires said:
X3
it says $217.00 now wtf?
Metal prices aren't exactly going down lately.
Sorry guys, that is correct metal is going through the roof.
That's allright, i'm buying one anyways.
You put out a quality product!
MEGABU
3,092
Blue Island, IL
i ordered this kit and installed it in less than 2 hours(i was in no rush). it went in with only one modification. the rear line fitting that came with the kit was for smaller diameter line, so i drilled it out & reflared the stock line. problem solved! the front line threaded right in, filled, primed, & bled the system, and it works beautifully!!
PONTIACMAN3
459
Manville, NJ
DOES ANYONE KNOW WHAT MASTER TO USE WITH STRANGE DISK IN THE FRONT AND STOCK DRUMS IN THE BACK??????? i HAVE A PROPORTION VALVE THANKS
